Anyone know where I can get some flat sheet for use in constructing a body plug (aka buck or pattern). Thermoplastics such as polythene and ABS are no
good for this as polyester resins such as are used in body filler will not stick to them.
Whatever I get needs to be bendable but not too flexible.
Any ideas?
John
i got a freind that makes signs for buildings i used his sheet for various panels in my car,bends when heated,cuts and drills well i will try to get hold of him you can glue it with plumbing solvent if that gives you a clue to its make up
What about PU foam John? It's great for plugs/resin, and it shapes beautifully. I'm not sure though if it's available in thin enough form to be bendable.....have a sheet split?
John,
If it's of any help, I used 1/32" (3) ply for making scuttle plug.
Got it from my local model shop. Not cheap (about £6 for 4' x 1')
Bends very well in one direction, quite well in the other, but not in 3d.
Simon
