Ali or stainless rivets?
Hasse - 31/1/03 at 06:15 PM
Hello,
I´ve read that you need to use stainless steel rivets to "bond" alu to the steel tubes.
Is this true?
Any experiences from using alu rivets?
I have a welded steel floor, but everything else will be alu.
Thank´s in advance.
/Hasse
Mark Allanson - 31/1/03 at 09:45 PM
If you are going to use a hand riveter, you are going to get tinseenotinitis, tenosetintous, tinisinitinitis,...........really bad wrist ache, S/S rivets are hard as hell
Viper - 31/1/03 at 10:10 PM
go with the stainless, much better in the long run..
stephen_gusterson - 31/1/03 at 11:07 PM
most people seem to be using alu they are cheaper and easier to work with.
the long run only applies if you know you are gonna keep the car a long while.......
also, a lot of people use a bonding agent - like sikaflex - to help hold the alu to the frame between rivets.
atb
steve
kingr - 3/2/03 at 12:46 PM
I think I'll use SS rivets, the sound of 101 rivet heads jangling around in my chassis tubes would probably drive me insane. Plus I've got a air driven hydraulic riveter, so I may as well make full use of that .
Kingr
