what the best way to fit these items..
is it best to fit the bonnet then line up and fit nosecone..
or
fit the nosecone and then line up and fit the bonnett
the reason i ask is because its very difficult to line up and estimate where the lampbar holes go and try and visulize the bonnet gaps
I did nose, bonnet then scuttle.
Worked a treat unlike last time
Last time i had a gap on one side between the front of the bonnet and back of the nose cone.
Nosecone....scuttle then fit bonnet as bonnet can be trimmed down if need be
we put nosecone bonnet an scuttel all at once then fixed nosecone then scuttle then the bonnet hope that helped
Tri
