if you replace a radiator that has a cap with one that hasn't, I take it you need to fit an expansion tank with cap?
I think you do, if you don't have a pressure release somewhere this happens when you overheat for the first time:
http://www.locostbuilders.co.uk/viewthread.php?tid=35444
Raceline dont use a header tank or a cap on the radiator .
They have the thermostat on the engine.
The system finds its own levell.
Yep they do , but it isnt on the rad
<------------------as seen in avatar
One question on this - on mine it has found it's own level, but is not full to the top. Does this not mean that there is going to be air in the system?????
