Can you guess what it is yet?
Avoneer - 14/3/06 at 09:59 PM
ecosse - 14/3/06 at 10:05 PM
rear wheel arch mould?
DIY Si - 14/3/06 at 10:08 PM
A really big minging green cheese wheel?
indykid - 14/3/06 at 10:08 PM
maybe a little further forward than a rear arch? bracketing will be a bugger though!
looks promising.
tom
Or a loo seat in the making for someone with a REALLY wide ass?
DorsetStrider - 14/3/06 at 10:08 PM
A sort of rabbit type thing?
mookaloid - 14/3/06 at 10:12 PM
Spare wheel cover?
ProjectX - 14/3/06 at 10:26 PM
Jennifer Lopez's bog seat!
billy - 14/3/06 at 10:26 PM
CHEESE gromit
Humbug - 14/3/06 at 10:27 PM
Wheel for a blind hamster?
Avoneer - 14/3/06 at 10:38 PM
Any more ???
Anyway, it will be a 180 degrees front cycle wing buck with a very close fit on 13" wheels.
Nobody makes cycle wings to suit a 13" so I though I'd have a crack myself.
Watch this space as they say - will take a few weeks though!
Pat...
NigeEss - 14/3/06 at 10:38 PM
Cover for a flat tyre ?
Chippy - 14/3/06 at 10:54 PM
Would only make one comment Pat, don't make the same mistake that I did, and make the side skirts too deep. After fitting my guards I couldn't take the f*****g wheels of, Doh! ATB Ray.
k33ts - 14/3/06 at 11:02 PM
i couldnt get my wheels of easily so i welded a nut in the supports and thred locked bolts in so i could remove wing before wheel.
also enables you get wing closer to the wheel.
Avoneer - 14/3/06 at 11:08 PM
Cheers.
They were close on my Avon, but just right.
Approx 10mm air between arch and tyre.
Pat...
Guinness - 15/3/06 at 07:35 AM
Are you going to put vents in the top, or a little wing ala Caterham and the CSR? to help reduce pressure under them?
Or is the plan to get them so close you don't need them?
Mike
Triton - 15/3/06 at 10:10 AM
Good for you Pat..at last a cover for those daft 2 quid coins.
Sent you u2u by the way.
Mark
Hellfire - 15/3/06 at 11:06 AM
It's a round of Edam with a puncture...
