Grille mesh
I have made , but not fixed the grille below.
I have been advised , that it may not offer enough airflow to the rad.
Any experience or thoughts on this, before I give it to the wife for making spaghetti?
I was tempted by this design but when you look closely it has more metal than holes - which must be a bad thing for airflow. In the end I went for the
conventional diamond mesh which appears to flow better.
I suppose it wouldn't hurt to try it
[Edited on 11-4-06 by RazMan]
Considering the b***dy great hole in the front of the Locost nose cone, I would think that you would have no problem with the grill shown. As it's fairly easy to remove the nose cone, why not just try it, if it gets too hot whip it out and fit something less filling, but don't think you will need to. IMHO. atb Chippy
Colin,
Looking at your archive it looks like you're using an escort rad which must be larger than the original fireblade one so I would be suprised if
you are short of cooling for your motor with that grill.
Ned.
Depends what engine you are using... ZX12R you would overcook the engine!
Hellfire, its a fireblade in his archive
Originally posted by ned
Colin,
Looking at your archive it looks like you're using an escort rad which must be larger than the original fireblade one so I would be suprised if you are short of cooling for your motor with that grill.
Ned.
That's what i've used on mine
Just before it went bang
Only kidding seems to be fine.
Leigh
Colin,
Ned.
Leigh
Colin,
Ned.
surely it doesn;t matter how big the radiator is if you cannot get enough air through?
look nice though but I wouldn't use it; shopping trolley, you know it makes sense.
Really must get round to posting the details about the mesh supplies that I have used in the past....
Colin,
Ned.
true but running a larger rad you need less air flow to get the equivalent cooling as there is a greater surface area to discipate the heat.
Ned.
In the extreme I would probably agree with you, but I really think that this is taking it a bit far in the context of this thread. The grill pictured will be fine, or I'll eat my hat
It's only a grille!!!!
I'll give it a go, its made now!
it is not that simple; not only it is cosmetic - it does look nice - it functions to let air through. If it is inadequate, you risk cooking your engine, possibly damaging it so will cost more than a sheet of stainless mess.
Try this chap, he was very helpful to me with a piece fo 1/2" welded stainless mesh. If you want it orientated as diamonds, it will cost a
little more, as its cust form a larger area.
Nice quality mesh.
Still, he is helpful, and not too expensive.
I have no commercial connection other than being a satisfied customer.
Drop him an Email.
alan@porteousfab.co.uk
