ok, seats have been fitted but the rear bulkhead, the bit that the seat backs rest against, is plain aluminium that looks a bit out of place.
so what do I do? paint it or pvc trim? or get used to it.
photo please .
The nicest I've seen are painted in a crinkle type finish. Preferable to covering in other way imho due to potential effect of rain!
Not very exciting but preferable to the ali sheet I had before. Single ABS sheet won't disolour from water ingress and slightly better for NVH
(noise vibration harmonics).
[img][/img]
Using black PVC or it's ABS alternatives will absorb heat - expand into bumps and bulges around the rivets and possibly split and generally degrade quicker than Aluminium. Agree about noise damping but WTF?
I found some incredibly thin zintec at the scrapyard for free. You can cut it like paper and it's primed one side if you want to paint it. I can't hear much when the car's running anyway . If the aluminium bothers you stick some upholstery vinyl or carpet over it.
Ok so NVH isn't on everyones list but it has reduced some resonaces!
My ali sheet lasted about a year before it was a dented and scratched. So if the ABS lasts that long I'm happy.
