Hi all
I'm giving some old alloys a repaint, gave them a coat of etch primer a couple of days ago, all went fine, tonight i gave the first on a coat of
filler primer, looked ok, went beck 10 mins later and theres cracks all over them, any ideas whats wrong?
Oooo! Nasty
Hope you can fix it mate.
Dried too fast maybe?
A car sprayer next to my m8's garage was moaning the other day that it was too hot to spray things.
Insuficcient flash off time between coats, the underlying coats are still soft and now cannot dry, the top coat surface has dried but is floating on the uncured sub coats, hence the cracks
Hi, I was wondering if its too hot, I had only done 1 coat tonight, i'll sand it off and try again when its a bit cooler
Adrian
Adrian
I ment next week when summers over
Anyway i'm spraying out of a can
Adrian
