What thickness/gauge ali have people used for their tunnel and back panel?
16g half hard same as in the book. We used some thinner stuff on a mates car but it rippled every time he touched it. You couldn't rub it without
denting it.
yours, Pete.
Same, bends and cuts loverly. Just used a jigsaw with coarse metal blade.
it that 1.6mm?
Originally posted by MK9R
it that 1.6mm?
...also = 1/16" inch, near-enough!
One of those useless things that catch my attention...
DJ
i used 1mm 20swg for all panels. I found that it was great to work with and saves a lot of weight.
IIRC tiger recommends 1mm
Kingr
used 1.2mm stuff from my local fabrication firm, cuts easily with a jigsaw and is solid too.
I'll be using Ali for the side panels but for the seat back I've welded in 20 swg, bit heavier but a lot more solid and I think (hope) it
will help stop the chassis twisting. Looking at the book, Riveted Ali looks a bit flimsy. I've also done the front end mods i.e. v brace, welded
front bottom panel and triangulating the very front part of the chassis (forget the tube letters). I will also weld in 20 swg for the sides of the
tunnel.
This (hopefully) will give me a stiffer chassis for not much weight.
Engine is a 1300 standard xflow - may not be as fast / quick as others but cornering is the thrill for me. 40 round a 90 is probably better than 100
round a 120 (and a bit safer)
I'm no expert, just my way of thinking. I'm sure you'll point out the error of my ways !
Great forum, learnt lots, need to learn more.
