Hi All. May I pick your brains please?
What's the options for side bonnet catches? What have you used? (And where did you get them)
I would appreciate your ideas as the next job is the engine side panels, and I'd quite like to sort out the catches before I make them.
They would need to be SVAable.
Many thanks,
Paul G
If you want the neat solution you can use flush dzus fasteners, they are a pain to line up, but look the biz in my opinion.
Otherwise you can use the rubber over centre catches as supplied by most of the manufacturers. I got mine from RS...will look out the number for
you.
RS stock number: 288-8464
[Edited on 25/2/07 by flak monkey]
I think Dzus would suit best, would be a crime to spoil them lines !!!!!!!!!!
Jason
hi, i got these :-
http://www.rallydesign.co.uk/catalog/product_info.php?products_id=12816
from rally design, really easy to fit, and def sva friendly
wow look at the panel gaps! incredible
definitely Dzuz....
(sounds like an advert!)
but as above it would spoil your shut lines with the other ones...
Shame to have to fit anything Paul. Dzuz or the Aero type fittings ? How about no visible securing device?
You could try something really trick and invisible using two (normal) bonnet release fixings, one runnind down each side, that is some sort of slide
release?
You could ensure it wouldn't fly off in the wind by doubling one back so the release cable itself is being operated the wrong way, thus opposing
the other one???
just an idea for you (not sure it would work, but once again, the shut lines deserve something a bit special...
Steve.
Aerocatches?
Take a look at the westfield locking kit...should give you some ideas on how to do it without spoiling the lines....
The bonnet has a double fold and this needs to be clamped to the chassis in the direction
of the green arrows, as my red G clamp does in my first post.
The scuttle & nose have a closed cell rubber strip that the bonnet needs to be pulled down onto.
Would the Aero or Dzus catches do this? (any pics?)
The rubber ones look good but a tad expensive at £28 + for 4.
Thanks very much for the replies so far.
Paul G
[Edited on 25/2/07 by 907]
The Dzuz catches won't pull the bonnet down to the chassis but the Aerocatches will . Also I think they are available in polished ally?
I do have these but the Protex ones (No1) won't pass SVA, and 2 & 3 won't pull down.
I don't mind bits & bobs showing on the car because as it is it looks very plain.
A splash or two of colour (even black) takes the blandness away IMHO.
Paul G
The Aerocatchs that Razman has shown look very neat . If I ever get around to making the new bonnet thats what I will use . They are also adjustable to some extent.
I used them on my car and they are adjustable so you can compensate for wear later on. Although they are only available in black plastic they can be
flush or surface mounted. I bonded them to the inside surface so that fasteners were not required (another option) They will not really pull a gap
closed but will hold it firmly once closed - so you give a little hand pressure and then flip the catch closed.
[Edited on 25-2-07 by RazMan]
you have been busy, Nice one
Originally posted by RazMan
I used them on my car and they are adjustable so you can compensate for wear later on. Although they are only available in black plastic they can be flush or surface mounted. I bonded them to the inside surface so that fasteners were not required (another option) They will not really pull a gap closed but will hold it firmly once closed - so you give a little hand pressure and then flip the catch closed.
Not cheap but well worth it imo
Tifosi sell them
Non-locking: £35.25 Locking £39.45
Oh and you can paint them body colour as I did and they blend in nicely. Maybe alluminium paint in your case Paul?
Thanks very much for posting those Raz.
I take it that's a price for one, so I'll give them a miss if I may.
Looking forward to seeing your car one day. Perhaps at an E/A meet. Love it.
I tried to get the mag on Saturday morning but they had sold out.
You must be dead proud.
Paul G
I did have a look on the Westfield site Steve.
Found them.
There was a price but no pic, so I did a Google image search and found Westies with all sorts fitted.
Thanks everyone
Paul G
That's for a pair!![]()
Don't panic, it appears in the April edition .......... and yes, I am![]()
I miss read the post by mistergrumpy as well then. (What Kit Car thread)
Am I right in thinking April edition should be out in mid March?
..... oh God I'm such a tart
Hi.
Been thinking. Oo er.
I'm trying to keep it simple (read cheap).
I had a play tonight with a c/s M8 screw.
If I make 4 lugs and weld them to the chassis, drill, tap M8, and countersink to 20mm dia,
then when the screws are tightened it pulls a c/s in the ally sheet.
This would act as a locating device when refitting the bonnet.
The screws can be done up with a 10p piece once the c/s is formed.
What do you think? It saves a shed load of beer tokens.
Paul G
Nice and Locost, but could rattle loose me thinks ??
Jason
Yep, that's why Dhuz fasteners were invented
Would a 2p piece do it, we don't want to go too mad do we ?
they look good, I cant see any problems with the addition of some PTFE tape
You do remember your engine is a LOTUS, getting to the engine quickly and often will be essential.
Is the ten pence to call the RAC.
You'll be OK with a 2p coin - most of them are made of steel these days, with a thin copper covering!
I like, except for the potential for losing the screws if you take them out at a filling station or whatever. Suppose you could keep some spares in
the car though.
cheers
Fred W B
Would the screws have a big enough surface area to spread the load without pulling through the ally? Perhaps some button headed stainless screws might be better and still be SVA friendly?
This is an idea I had a while back for a "hidden" fixing (sorry for abusing your Paint creation!).
Essentialy you mount a couple of pins into the chassis rail, and a strip with keyhole cutouts is used to lock into a recess machined into the pins.
This can be moved by a lock mechanism from the outside. There are a some issues to solve, how do you retain the strip in place for starters (a couple
of slots cut in it and an a screw, washers and spring and nut to keep it under tension maybe).
By suitably forming the strip around the keyhole it could be made to pull the bonnet down as it engages with the pin.
I'm going to dismiss the vibrating loose issue.
Vibration???? From a Lotus engine/????
Great British sports Cars have SVA rubber pull down catches on Ebay at £10 a pair ATM, I went for this.
I do like the screw in solution, a bit of old inner tube rubber on the receiver surface may be enough to prevent them rattling loose.
You may be able to get an M5 star washer to go up the thread of the screw to save it falling out of the panel when you unscrew it, if not try some UNF
star washers about the same size.
I wish I had seen this or thought of the pull in countersink for my dashboard before I fitted it with cups!
well done!
Caber
