To bond or not to bond ?
Kosmo - 31/3/07 at 08:56 AM
This may be a stupid question but I just need some confirmation.... I'm about to start panneling my Striker and was wondering do I need to use a panel bonder or sealer when fitting to the chassis, it mentions nothing in the build manual but I know I have seen some post's on here about bonding ?
Thanks,
Kosmo.
BenB - 31/3/07 at 09:36 AM
Bonding panels on is a good idea. Makes the chassis much stiffer than rivetting alone. Infact, if its done properly you can avoid rivets (but personally I wouldn't trust myself to do it properly).....
Only downside (other than the cost of a couple of tubes of Sikaflex and the minimal weight) is it makes removing the panels more difficult in case of crash damage.... but its worth it...
jos - 31/3/07 at 09:48 AM
ot sorry
ullo kosmo
i'm in telford too. if you need any help give us a shout
btw I bonded mine. it helps reduce annoying rattles when driving too
RazMan - 31/3/07 at 10:13 AM
Don't forget that it ensures your panels are waterproof too - mind you if you get caught in the rain it means the water can't drain OUT either
Kosmo - 31/3/07 at 10:31 AM
OK... next question, where's the best place to get Sikaflex from and what type did you use ?
Thanks again, Kosmo.
RazMan - 31/3/07 at 10:37 AM
Your local motor factor or paint factor - not neccessarily Sikaflex though. Tigerseal is another brand and there are a few others which are a bit cheaper but just as good IMO.
jos - 31/3/07 at 10:49 AM
Wurth body panel adhesive - £8.00 + P&P from
www.mac1motorsports.co.uk
In fact Ive got an only just opened hardly used tube sitting in the garage at the moment.
[Edited on 31/3/07 by jos]
Avoneer - 31/3/07 at 01:52 PM
Silicone will be fine if you are riveting as well.
Pat...
