2 pack paint question
myeates - 4/10/07 at 05:00 PM
hi guys will post some pictures of my car soon as painting top coat this weekend, got some 2 pack yellow and was told that 2 pack would not be available very soon.
the question is if i dont have enough of the 2k paint can i over coat and finish off the colour with some water based or single pack paint without any problems??
wont be long now
PaulBuz - 7/10/07 at 03:05 PM
I don't want to teach you to suck eggs, but you're not spraying at home are you?
2 pack (iso.) paint can & will kill you.
Do a search on here.
If you are spraying in a proper booth with full protective gear (air fed mask etc) then spray away!!
To answer your question once the 2 pack has cured you should be able to overspray with what you like.
myeates - 7/10/07 at 06:16 PM
thanks mate yes spraying at home but with the aid of a proper air fed mask, protective gear and ventilation did all the research before hand as know just how deadly the stuff is if not used with care
thanks
