SVA Dash
LBMEFM - 12/11/07 at 10:34 PM
I was going to fit my Fireblade clocks behind the steering wheel for the SVA
But I would like to do the job just once. Is there is anyway I can fit my clocks-oil & fuel gauge and flush fitting s/steel swtches in the middle of the dash and still pass the SVA, maybe a padded surroud or something.
Regards
Barry
bigrich - 12/11/07 at 11:09 PM
http://www.locostbuilders.co.uk/viewthread.php?tid=62184
dash is Steve (worX)
just a bit over half way down the 1st page
Rich
[Edited on 12/11/07 by bigrich]
worX - 13/11/07 at 05:53 AM
Hi Barry,
If you can get your clocks behind the wheel then great! - I couldn't! (which is why they are where they are in the pic!)
I made a template in card and then in a sheet of aluminium, which you are more than welcome to, if you want it?
The template is currently with Andrew.Carwithen, but I am sure he would post it to you as he was going to post it back to me at some point anyway!
I also used a DIY 'O' Ring kit to "encircle" the speedo/rev counter for SVA purposes and Andrew has kept hold of those aswell and I am sure will post them on to you to ensure your clocks will pass the SVA!
Drop him a U2U...
Regards,
