Was someone on here selling the 105mm headlights?
I'm after a pair, any other sites apart from rally design sell them?
Thanks for any help
Paul
got mine form ebay for about £65 for the pair.
We have just purchased a batch for use on the MEV R2 pic www.mevltd.co.uk. Ours are without brackets and bolted together as a pair for bikes. I could sell you a pair at £60 with bulbs if thats any help but you will have to make brackets. Regards Stuart
I got mine off e-bay for £45 +p&p and later found out the seller was Takumi on this site!
Nice bloke to deal with...sorted a postage problem for me.
Hi all,
Sorry to say I have no more LEFT!! at all..
I have a pair for myself, and thats it and I'm keeping them..!
For those who missed out on the matt black dominators I was selling,
>Ive found some chrome dominators for £29.99 each +£6pp each , mine were abit cheaper, and cooler in Matt black
Also they have 4.5" Bates style for £28.75 +£5pp
http://www.tab-customs.com/page5.htm
half way down the page.!
these are great if you want to keep the classic look.
I was down at RAF Woodbridge on Sat (Javelin were doing a trackday there) to exchange some lights to someone, they have their car there -westy, and
the difference compared to the 7" lights was massive, the westfield people claim 7mph in topspeed with 4" lights compared to 7".. thats
quite a claim..?
[Edited on 4-12-07 by takumi]
I have them available, in stock on my website at £69.95 a pair NO VAT, already separated, with separate wiring including bulbs, black or chrome. 10%
discount to all Locosters
I shall be getting some suitable brackets shortly, hopefully in stainless steel.
Oh, almost forgot + £6 P & P
HTH
Are these lights OK for MSVA?
What is MSVA? (motorcycles SVA?)
They are E-marked, and this is taken from the (Ithink) from the MSVA manual
Headlamps – dipped and main beam, both white; the dip pattern must be either kicked up to the left, a flat beam or else an alternative beam that “does not dazzle”.
Unhelpfully ambiguous.
MSVA is Motorcycle SVA. The manual does allow flat, dipped and US-UK style dipped beams. I believe, from reading the manual, that if it has the
correct E marks and the beam pattern is OK then then a light should pass SVA.
These particular lights are E marked. What E mark do they have? Presumably they must have passed some sort of test with some sort of vehicle in
mind.
The ones I have in stock are marked "E4", they have a flat dipped beam, to the very best of my knowledge they should pass MSVA without a problem, I do know of people who have got them thro mainstream SVA, but I also know of people who have failed, for this reason I sell them as "off road & track use".HTH
I've just re-read the MSVA manual. Unbodied bikes have a simple requirement:
1) does not kick up to the right.
2) does not dip to the right.
3) does not dazzle.
Bodied 3 and 4 wheelers have to meet specific beam patterns. Either the usual 15° kick up to the left when dipped, or meet the British American beam
patterns for both dipped and main beams.
The dipped beam pattern (below) is higher on the left than the right. A completely level beam cut off is not permitted, it seams.
So ok for ordinary MSVA but not for a full bodied vehicle for MSVA.
Guess that's why I sell them for off-road use - there is a simple trick to get them thro' the MoT, but unfortunately not SVA.
