bonnet scoop
2b_pablo - 5/12/07 at 03:02 PM
any nice westfield type bonet scoops out there?
be nice to aid airflow into the enginebay
cheers
JAG - 5/12/07 at 04:24 PM
I have more issues with getting airflow out from under the bonnet.
The nose seems to let loads of air in but there's nowhere for it to go except out underneath the body of the car.
tcr - 5/12/07 at 04:33 PM
we used a nice 1 from a local motorfactors ,its the sort of thing the maxpower boys use but looks at home on a proper car. we also made 4 3" holes either side at rear of the bonnet to help the extra air escape
[img][/img]
[Edited on 5/12/07 by tcr]
Humbug - 5/12/07 at 04:43 PM
I've got:
- ali round the rad to force any air that comes into the nose through the rad
- a small open-fronted scoop on the bonnet because of the height of the inletstuff
- a louvre on each side of the bonnet near the scuttle.
Never seem to have any problems with bonnet lift or overheating
robertst - 5/12/07 at 05:54 PM
hence the louvres in cateringvans
lotustwincam - 5/12/07 at 08:58 PM
Homemade scoop on nosecone to get more air in, and outlet in bonnet behind exhaust manifold.
Also home made sccop above carbs to feed them with fresh air and to clear the bonnet!
Bonnet scoops
Bonnet scoops
TPG - 6/12/07 at 01:18 PM
Any good to you?14" wide(ish)16" deep(ish)2 1/2" high(ish).£15 inc the postage.In the box and unused. Rescued attachment scoop.JPG
2b_pablo - 6/12/07 at 02:06 PM
will give it a blast
