Anyone have any clever way as to how the spare wheel could be held in its rear carrier?
Original 7s had a nice strap attached to the top bar at the back that went through a wheel slot. I will be doing this if I ever get around to fitting
a spare wheel!
Caber
Long wheel bolt through to a plate behind the bodywork that has a wheel nut welded to it.
I assume you already have the carrier ???
Paul G
I going to make a kind of wheel lock to go through the back panel.
