Hi Guys,
Busy with new project, restoring Type 2 Veedubbleu Camper for my brother.
Need to replace the bottom of the rear quarter and also sills etc.
Question is, in the past I have always butt welded panels together say at the bottom of a quarter with mig. Is it better to use a joggler and over lap
them or will I run in to trouble?
Any other tips on Type 2 bodywork greatly received! The front bumper panel piece that is part of the body and sits behind the bumper needs replacing
but looks a bugger to get off!
Thanks,
Probably better asked on The Samba.
Cheers Tim, Ihave looked at a few forums but The Samba seems to be the best.
I will have a search.
Thanks,
if the sills are anything like they are on the beetle I feel really sorry for you, horrible, time consuming job
Cutting so much off will cause the shell to twist and then the doors won't fit. Before you cut anything do what I did (picture in my archive) and
weld tube braces across the door opening and across the inside.
Do each sill first (before anything else), one at a time, then the rear panels. If you can leave a flange from the old sill and weld the new ones to
that, that way you can easily hide the weld.
VW manage to make all the footwell panels on their car and vans terrible to replace and due to them being part of the heating system rotted very
quickly. You may have to cut some good metal away to get access.
Go slowly and be precise.
Originally posted by novacaine
if the sills are anything like they are on the beetle I feel really sorry for you, horrible, time consuming job![]()
Wooah tin worm! Looks from the archive though that you are getting it sorted. My first car was a 1973 1300 bug, dehandled, raked, etc etc
Pointers are greatly received.
Thanks,
butt or joggle and plug it, either will work ok.
Just remeber the obvious but often forgotten tip if butting it. Lay the new panel over the old, drill and cleco or rivet them together, then cut
through them both down the line you want to butt weld them on with a panel saw, you then have a perfect joint to weld with no gaps.
Cheers for that tip.
