Afternoon all
need a solution to a problem. I'm trying to connect something with a coarse female thread to something with a fine male thread.
Basically I'm trying to use some shower hose to fit to the bottom of my headlights to run the cable in as I think it'll look tidy and be in
keeping with the car having chrome wishbones etc.
I know trivial and unimportant but seeing I've spent so much time on the rest of the car I thought it would be worthwhile.
Any ideas much appreciated
Nigel
[Edited on 4/3/08 by jabbahutt]
You will need some form of threaded adapter made up.
Bigger spanner?
Caber
glue or sealant?
I don't suppose for any reason adaptors with a coarse thread at one end and a fine at the other are used for anything in plumbing etc as if
they're available off the shelf it would be so much easier.
Cheers for the assistance.
Nigel
Try dropping into your local hydraulic manufacturor...(or pirtek)sp? They have a fair few adapters..
But as its not a critical part I would be inclined to come up with a less costly and complex solution...
Plastic metal onto the female thread with a bit of cling-film or ptfe tape on the male thread to stop it sticking?
Cheers, Pewe
grind off most of the coarse thread, bit of loctite or epoxy ,screw it up and it'll never come out.
[Edited on 4/3/08 by Mr Whippy]
1/2" BSP radiator bleed screw housing. (from plumbers, in brass or steel)
Remove the square headed pin and drill and tap the housing to suit the other thread.
Paul G
[Edited on 4/3/08 by 907]
Or in picture form.....
