What are peoples view on the cycle wing top indicators?
Im considering fitting them but im not sure on the look?
I had them on my first set of wings. It's a different look, not better or worse.
When the wing stays broke I decided to go for conventional indicators.
depends on the type etc
had them on my old rh2b and almost failed sva due to non radius edges
others face front look ok on some cars and stupid on others
all about preference, type, shape and colour
The added weight (admittedly small) will help break the stays. In my view the wings need to be as light as possible, as they are subject to constant shock
to get round the shock, i used rubber washers under the heads of the bolts and then rubber washers again underneath in between the wings and the
supports.
far less stress or grp cracking
there is a dax in complete kit car that has led's drilled into the cycle wings as side lights maybe you could use the same idea for your
indicators
just a thought
Like this?
I had them on my first car and they were ok, though i prefer the nose mounted type on my current car.
newark2005
It was the only piccy i could find HONEST
We're not complaining, honest!!!
Tis the standard option on the Striker but I went back to nose mounted when I changed the wings. Slightly easier to mount I suppose. The weight saving would be negligible but everything helps!
slightly off thread but i didnt think lights on the wings were allowed ie the leds as side lights drilled into leading edge as they will move
differently relatively to the body.
cos I was thinking of mounting some lights on the wings so tahat when you turn the wheels they illuminate the bend kind of like ford and vauxhall
adaptive lighting but there was a thread on here that said that was a no no
sorry for slight detour of thread
