What's the best GRP adhesive?
Sikaflex 292 ???
I'm wanting to join some stressed body panels together, so thought about bonding the overlapping parts and then glassing over all edges.
Well, Polyester resin is quite sticky stuff, and if you used it there wouldn't be any compatability issues
John
I'd use gelcoat to stick panels together - sikaflex will be a bit flexible .
^^^^^^^^^^^^ I agree
Any movement will just crack the bond line - use resin and do the job permanently.
Cheers guys... any particular product / brand recommendations?
