Arches
Macca - 9/7/02 at 10:40 PM
Must apologise first as this questions isn't in relation to a locost, but it could be so I hope nobody minds. I understand that the front arches must cover the width of the tyre/wheel but is there any legal spec as to how much of the circumference of the wheel/tyre must be covered for both SVA/MOT tests.
Hope somebody can help.
Cheers Col,
theconrodkid - 10/7/02 at 02:53 PM
Just looked in my book of words,it dosnt really say ,but looking down onto the wheel if you cant see the side of the tyre,and the wheel rim is covered by the mudguard you should be ok hth
Marcus - 11/7/02 at 05:58 PM
Somewhere in the deepest depths of my mind, I remember seeing 120 degrees of coverage required around the circumference. Don't know where I saw it, but it was many years ago.
Marcus
marcjagman - 12/7/02 at 10:32 PM
You are right, 120 degrees of coverage.
David Jenkins - 15/7/02 at 07:57 AM
On most of the Locosts I've seen, the front of the m/cycle mudguard is either above, or just in front of, a line drawn vertically from the front of the wheel rim.
