Quick CBS Wiring Module Query
TimC - 2/1/13 at 09:42 PM
Would I be right in thinking that Number 5 on the diagram below (main alternator connection) is connected within the module to Number 6 on the diagram (battery via starter).
Many thanks,
TC
umgrybab - 2/1/13 at 09:50 PM
I think it is IIRC. I can have a check on mine with a multimeter tomorrow if you'd like.
TimC - 2/1/13 at 09:52 PM
That would be fab if you don't mind.
Cheers.
omega 24 v6 - 2/1/13 at 10:40 PM
Haven't used or seen one BUT logically it should be.
eddie99 - 2/1/13 at 10:45 PM
+1
umgrybab - 5/1/13 at 10:00 AM
Millimeter agrees. These two are directly connected, somewhere in there...
Rich J - 3/2/13 at 04:35 PM
Hijacking this thread somewhat- I have the earlier version of the module on a Striker I'm rebuilding and 5 and 6 are also conected. The problem I have is that the battery runs flat as no. 6 is permanently live and conected to number 2 here:
here
The question is - is it safe to conect it to a switched live terminal somewhere else on the module??
The alternator is 40A so should the wire be rated to carry this?
Thanks in advance
Rich
umgrybab - 23/2/13 at 05:49 PM
here
Thanks in advance
Rich
Hey Rich, did you get an answer to this? I did not check back up on this thread since I last posted. I had the exact same issue you are having a few months ago and wondering if you still need help.
