pinto rad
redeye - 22/5/04 at 11:25 PM
i know this has probably been asked before but
what radiator has everyone used for thier
pinto engine?
id been given one from a westfield but it deosnt wanna fit.
cheers
mangogrooveworkshop - 22/5/04 at 11:38 PM
The polo rad (see zetecs photo archive) slightly tilted back 152 from westy and thirty bucks from partco (you may have the right one) I will see what the number was Zetec said use a 15 psi cap on the bottle. macspeedy is using a carpri rad
redeye - 22/5/04 at 11:58 PM
just had a look at zetecs rad, its not the same as mine
was plannin capri rad , heard they fit well?
also wonderin about wat alternator that every one else has used for the pinto?
stressy - 23/5/04 at 08:15 AM
Capri rad should fit but may well need considerable tilting back to do so.
Not exactly efficient but does the job.
Peteff - 23/5/04 at 09:12 AM
Mk2 Escort tilted back works for me. It's probably similar to a Capri radiator. I used the standard alternator with a bit shorter belt and moved the engine bay brace to the other side.
redeye - 23/5/04 at 11:01 AM
cheers guys
anyone got a capri rad that can give me the dimensions?
macspeedy - 23/5/04 at 11:45 AM
top to bottom 480mm and 485 side to side which includes some lugs for mounting, thickness is 60mm at lugs and 40mm for the core hope that helps
MK7 - 23/5/04 at 12:03 PM
I used a rad from a nissan Micra, went in upright pretty easy and so far seems to work quite well with my 1.8 pinto.
The expansion bottle that clamps onto the side / rear of the rad can even remain in situ.
scoobyis2cool - 23/5/04 at 02:35 PM
I've used a polo rad, I would recommend you use a 'pull' type fan that sits on the back of the rad, I have used a 'push' type on the front, it does fit but it's VERY tight between the rad and the nose grill
Pete
Mave - 23/5/04 at 05:42 PM
From what year/type is your Polo rad?
James - 24/5/04 at 12:46 AM
I've fitted a Micra rad too- though not run the engine yet!
A nice alternator is the one from a Bedford Rascal van. It's a Mitsubishi jobbie (I think they're the same in the Vauxhall version) and is really small and light.
I've made a braket from part of the Rascal bracket plus a small plate of 3mm. Seems to have worked well so far.
HTH,
James
Mk-Ninja - 24/5/04 at 07:37 AM
Micra radiator. Dead easy to fit, and comes with fan, switch and integral expansion tank.
bob - 24/5/04 at 08:29 AM
MK2 escort rad blanked off at the filler worked for me. Rescued attachment front no body.jpg
