Mr Whippy
posted on 16/2/09 at 07:58 AM |
Windscreen lower scuttle seal
Anyone got a particularly nice way they’ve done this that looks nice from both the outside and the inside? I need to do it differently to how it was
done before due to a new dash design. Last time all the black goo was hidden behind a trim panel but thats not there anymore and so need something
good looking but that also will keep out the rain effectively.
posted on 16/2/09 at 09:49 AM |
Have you had a look through Woolies range of seals?
http://www.woolies-trim.co.uk/
Maybe glue the rubber seal to the top of the scuttle to keep it in place and give a watertight seal, then fit a thin strip of closed cell foam to the
bottom edge of the screen surround to allow for any movement/tolerance.
Mr Whippy
posted on 16/2/09 at 10:20 AM |
Ta, looking through the range I think this bonded to the base of the glass should work, another prob solved
