Author: Subject: B**ger
Dickyboy
posted on 13/4/09 at 01:07 PM Reply With Quote
B**ger
Just getting the scamp out for summer and the windscreen has got a hit from the sparks from the angle grinder, which seems to have pockmarked the glass, very badly. It is flat laminated glass, will 6 or 8 mm safety glass as used domestically do? If not anyone know where to source a new screen?
Mr Whippy
posted on 13/4/09 at 01:12 PM Reply With Quote
don't ever use safety glass for a windscreen, if it shatters at 70mph (assuming a scamp can even go that fast ) the small chips will fly into your eye's
most autoglass places will be able to give you the contact details for flat screen glass fitters, usually about £30-£50 depending on how big it is
John Bonnett
posted on 13/4/09 at 01:53 PM Reply With Quote
Autoglass in Cambridge will certainly supply and fit a new screen for you and the people I used, Keen Screen Services @ http://www.bview.co.uk/listing/1325246/A1-KeenScreen-Services-in-MK44
hth
John
austin man
posted on 13/4/09 at 04:48 PM Reply With Quote
You can Buy laminted glass from any glass company just give tham a template and they will cut and supply it.
Toughened glass shatters into 100s of little pieces, laminated cracks
