Author: Subject: Bending Aluminium Tube
Dave Bailey
posted on 30/3/10 at 09:44 PM Reply With Quote
I need to bend some aluminium tube into an s shape with fairly tight radius.... Anyone know if this is possible with about 12 mm diameter tube?
thanks
Dave B
omega0684
posted on 30/3/10 at 09:47 PM Reply With Quote
how tight are you talking? Would you not be better to buy pre-bent tube?
ReMan
posted on 30/3/10 at 09:52 PM Reply With Quote
Aluminium is no good for a roll bar
daniel mason
posted on 30/3/10 at 09:55 PM Reply With Quote
especially 12mm!
Dave Bailey
posted on 30/3/10 at 09:56 PM Reply With Quote
i need to raise my headlights so probably need 2 inch radius. i didn't know you can buy pre bent!
Dave B
Dave Bailey
Dave B
austin man
posted on 30/3/10 at 10:04 PM Reply With Quote
plumbers Pipe bender ? would depend on wall thickness.
There was something on you tube where you tape one end up fill with sand and water then seal the top. then bend around your former whuch could bs a radiused piece of mdf etc. the sand stops the tube collapsing
boggle
posted on 30/3/10 at 10:10 PM Reply With Quote
you may need to anneal it first...depending on the grade....
u2u me for details
thunderace
posted on 31/3/10 at 08:20 AM Reply With Quote
would it not be very easy just to do it in copper ?
2cv
posted on 31/3/10 at 08:48 AM Reply With Quote
I'm not sure if I have understood correctly, but are you expecting 12mm aluminium tube to be rigid enough not only to hold the weight of the lamps but also to stop them vibrating?
posted on 31/3/10 at 10:32 AM Reply With Quote
indeedy.
can you describe the problem, ideally with photo of the lamps so we can advise - your solution does not sound particulalry sound.
Dave Bailey
posted on 31/3/10 at 09:12 PM Reply With Quote
can you have a look at the luego forum and see my progress pictures. This will show you the problem.
thanks
Dave Bailey
2cv
posted on 1/4/10 at 06:39 AM Reply With Quote
Lights are mounted in the same way on this car with indicators incorporated on the same bracket. However the tube is steel and 2mm wall thickness.
Bracket like this are available from Caterham.
https://www.caterhamparts.co.uk/product_info.php?cPath=123&products_id=4780&osCsid=f813dbec0bf737eacb954f556c8ad661
[Edited on 1/4/10 by 2cv]
