Author: Subject: Repairing a slight dent/dink on the nose cone
karlak
posted on 8/4/10 at 05:48 PM Reply With Quote
Ticked another little job of the list this afternoon. The radiator cap fitted to the Indy was touching the underneath of the nose cone - So I have lowered the radiator a few mm so it is now not touching the nose cone.
Thing is, where the cap has been touching the underneath, it has pressed it upwards slightly and has made a "inverted" dent that can be seen on the nose. Any ideas how I can "push" this back down ? Anyone done anything like it before - Obviously bit concerned about cracking the gel coat.
cheers
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
Triton
posted on 8/4/10 at 06:18 PM Reply With Quote
I doubt you will be able to do much with that as the cap would be hot and helped cure the grp that shape.(weird stuff grp) Only thing I can suggest is repair the underside with grp and flat down the gel side and slap a sticker on it as cheaper than buying a new nosecone.
www.tritonraceseats.com
www.hairyhedgehog.com
posted on 8/4/10 at 06:53 PM Reply With Quote
I wouldn't bother. Just go for a nice long drive and with a bit of luck when the nosecone gets hot (being sat over the radiator it sure should do) it'll sink back down again
deltron63
posted on 8/4/10 at 07:31 PM Reply With Quote
heat it gently with a hot air gun and push the dent down. if you can blow cold air on it even better to cool it at work i call it my rapid heat,rapid cool method
