smart51
| posted on 7/6/10 at 11:19 AM |
how far from the front of the vehicle are you allowed to have your headlights?
If you can maintain the 45° viewing angle, how far back are you allowed to mount your headlights?
Stott
| posted on 7/6/10 at 11:44 AM |
I don't think this is clearly defined in the manual (distance toward rear) but the viewing angle is 45 deg inward but 80 deg outward unless you
are using side marker lamps to supplement them, which reduces the outward angle requirement to 45 deg IIRC
( was a fail point on an IVA I went to last week)
[Edited on 7/6/10 by Stott]
A1
| posted on 7/6/10 at 01:13 PM |
as far as im aware you could have them at the rear, as long as they meet the illumination tests...
mad4x4
| posted on 7/6/10 at 04:12 PM |
Look at the Hideous Multipla (Fiat) it had lamps under the winscreen at the back of the bonnet
Scot's do it better in Kilts.
Nash
| posted on 7/6/10 at 04:16 PM |
Its to do with the angle of projection and where you can see them from in front of the vehicle.
IVA manual will tell you but my examiner stood to the left and right of the car and made sure he could see the beam and it wasn't being overly
obstructed.
.........Neil
................Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
A1
| posted on 8/6/10 at 10:50 AM |
whats wrong with the multipla...its gorgeous
Guinness
| posted on 8/6/10 at 11:30 AM |
I think the Atom splits the functions, of positional / side lamps at the front and main headlights at the scuttle:-
| posted on 8/6/10 at 03:03 PM |
So, in theory you can mount them way back and high enough above the bonnet line to not cause any obstruction...
