Author: Subject: Painting a windscreen frame
prawnabie
posted on 11/6/10 at 02:48 PM Reply With Quote
Hi Guys
I am going to take my windscreen frame apart this weekend to paint the frame black as the aluminium is a bit marked now. What primer do I need and which kind of paint/lacquer do I need to match the primer.
Shaun
austin man
posted on 11/6/10 at 03:13 PM Reply With Quote
you will need an etch primer these are better at adhesion than standard primers, you can paint it with anything then cellulose acrylic, smoothrite etc
Blackbird Rush
posted on 11/6/10 at 03:32 PM Reply With Quote
Had mine, etch primed and powdercoated....
prawnabie
posted on 11/6/10 at 03:46 PM Reply With Quote
Thanks for the replies
Can you get etch primer from halfords?
austin man
posted on 11/6/10 at 03:47 PM Reply With Quote
I believe you can but it in spray cans so Halfrauds should sell it
YQUSTA
posted on 11/6/10 at 04:27 PM Reply With Quote
Halfords link
"If in doubt flat out"
Colin McRae
deltron63
posted on 11/6/10 at 07:15 PM Reply With Quote
wear a mask, that acid 8 is nasty stuff. it works well though.
