jabbahutt
posted on 8/11/10 at 08:04 AM |
attaching pop studs to body work
Morning All
I've seen several photos where it appears that normal pop studs have been used to attach hoods etc to the car. How is the male part of the pop
stud attached to the body work? any photos of the attaching method much appreciated.
Nigel
Grimsdale
posted on 8/11/10 at 08:47 AM |
usually rivet, but you either need a spacer (such as a small bolt) to ensure you can pull against the rivet, or shape the end of your rivet tool so it
fits inside the press stud.
eznfrank
posted on 8/11/10 at 08:53 AM |
I used some small machine screws and a bit of locktite,
JeffHs
posted on 8/11/10 at 09:44 AM |
I used pop rivets with a home-made mandrel to set them, but be aware that it is very likely that the rivet head may
still foul on the inside of the female fitting. I've had a lot of trouble with mine - some of the poppers are almost impossible to latch. I
didn't use countersunk rivets so I ended up drilling most of the rivet heads away with an 8 mm bit to create the necessary clearance.
Alan M
posted on 8/11/10 at 12:22 PM |
I had and still have problems with mine, hard to pop on and off etc. There must be a good solution and I'm not certain it's pop rivets.
wicket
posted on 8/11/10 at 12:34 PM |
I turned the head of the c/sink pop rivet down until it was a snug fit in the stud housing.
[Edited on 8/11/10 by wicket]
Bluemoon
posted on 8/11/10 at 03:51 PM |
Use tenax fasteners much better IMHO (but not cheap!)
posted on 8/11/10 at 04:23 PM |
As said it's difficult to get the rivets to pop off cleanly (I used some v small washers as a spacer) and as with others I've had problems
with a few poppers.... I think it's the nature of the beast with pop studs... I wouldn't use them next time...
Mix
posted on 8/11/10 at 04:53 PM |
Hi
Hope I'm not teaching people to suck eggs - but - if you are using pop rivets to secure things to fibre glass you need to put a suitably sized
washer, (referred to as a burr) on the tail of the rivet to act as a load spreader. This should also have the effect of causing the mandrel to break
when the rivet 'pulls up' against the burr and hence not protrude through the rivet head and, in this case, not interfere with the closure
of the female fastener.
Regards Mick
snapper
posted on 8/11/10 at 06:40 PM |
You can use peel rivets, these work the same as pop rivets but peel back leaving 4 legs, still need some washers behind.
I used countersunk machine screws and nylocks
I eat to survive
I drink to forget
