Author: Subject: alternative to carlite ? brush on rubber underseal stuff
givemethebighammer
posted on 14/11/04 at 08:09 PM Reply With Quote
a while back someone was talking about using something from B+Q instead of the "carlite" brush on rubber stuff you use under your arches etc to stop crazing of your gel coat from flying stones.
anyone remember ? was it any good ?
thanks
Donners90
posted on 14/11/04 at 11:11 PM Reply With Quote
NF Auto
NF Auto do something like it called Wunderseal.
http://www.nfauto.co.uk/wunderseal.htm
DaveFJ
posted on 15/11/04 at 01:52 PM Reply With Quote
IIRC it was a rubber roof sealing compound....
dunno if anybody tried it though...
Dave
locoboy
posted on 16/11/04 at 12:04 PM Reply With Quote
from what i remeber someone used the goo used to stick felt to wooden roofs - did the job well too.
Locoboy
theconrodkid
posted on 16/11/04 at 08:27 PM Reply With Quote
i used the roofing stuff,easy to apply,needs a couple of coats tho
who cares who wins
pass the pork pies
givemethebighammer
posted on 16/11/04 at 08:44 PM Reply With Quote
thanks people any particular brand or type I should be looking for ?
thanks
wilkingj
posted on 16/11/04 at 10:27 PM Reply With Quote
I use StoneChip from the local car place. easy to apply with a compressor and Schulz Gun. Goes on thick, and can be overpainted. Used it on last 3 rebuilds.. Is this other stuff cheaper then?.
I seal seams with Car Brushable Seam Sealer (not cheap), then cover with Stone Chip and sometimes paint depending on where it is on the vehicle.
Best Regards
Geoff
http://www.v8viento.co.uk
macspeedy
posted on 16/11/04 at 10:41 PM Reply With Quote
on the mini i had i used underseal with wax oil built in great stuff re apply for better results, bit messy though
