Author: Subject: Bonnet bump stops
Slimy38
posted on 27/4/24 at 04:44 PM Reply With Quote
Bonnet bump stops
On my Healey body I have the body tub and the bonnet as separate pieces. The body tub has a 'lip' about an inch deep, that the bonnet sits on when closed. However, the mould isn't overly even, neither is the thickness of the bonnet. At the minimum there's a 3mm gap, at the widest it's up to 8mm.
I need to align the surface of the body and bonnet, as well as giving the bonnet a rubber surface to sit on. I was going to use different thicknesses of rubber, but it occurred to me that tin tops often have adjustable 'screw' type rubber bungs for boot lids and tailgates. To tighten or loosen them they can be twisted and the 'thread' of the rubber winds it in and out.
I think they would suit my needs perfectly, but as always with Google you have to know the name of the them before you can find them. So does anyone know what they would be called?
gremlin1234
posted on 27/4/24 at 08:39 PM Reply With Quote
bonnet cone rubbers
ref: the part for triumph herald spitfire etc goes into a circle on the bonnet / body, locates, and sets hight as well.
https://rimmerbros.com/Item--i-612962
Partofthechaos
posted on 29/4/24 at 07:48 AM Reply With Quote
If you have a friendly scrap yard near by a quick walk would provide you with a lot of different options. I've kept the ones from my donor car as they looked so useful. Not found a home for them yet though...
stevebubs
posted on 29/4/24 at 01:23 PM Reply With Quote
Have you thought about using furniture feet upside down? Finding a screw-in rubber foot should be relatively cheap and trivial...
Sylva Fury
Slimy38
posted on 29/4/24 at 01:42 PM Reply With Quote
Hmm, interesting idea. I did manage to find the things that I was after;
https://www.ebay.co.uk/itm/225952122389
Although buying them new is going to be expensive, but that's where a visit to the scrap yard would work!
