JohnFol
posted on 25/4/03 at 04:37 PM |
Rear screen
I've been asked to source / suggest a part for a W******d owner. What he is after seems reasonable and even possible to fabricate all bar a few
bits.
What he wants is a rear screen, ie a rectangular piece of perspex that fits inside the rear roll bar.
The perspex, and bit of trim around the edge is easy, but mounting it is difficult. Since he is of the school whereby you "buy" a kit car
already made, he does not want to cut holes or weld anywhere. Also the bar is chromed so this would not be ideal.
So, I am after some semi-circular clips that are preferably plated, with a rubber liner, about 2" diameter and a nut/bolt fastener.
Can anyone help??
andyd
posted on 25/4/03 at 04:44 PM |
You could make him some and then charge him a small fortune for them.
Maybe I'll just shut right up!
GO
posted on 25/4/03 at 05:06 PM |
how about cut some slots in the perspex, about 2inches wide, one on each side at the bottom and two on the top. and then buy some velcro that'll
wrap around the rollbar? Easy to attach and remove. I reckon it'll be strong enough to stand upto the buffeting. Cheap and easy too.
[Edited on 25/4/2003 by GO]
Dave Ashurst
2" exhaust clamps from a motorbike shop plus some strips of inner tube?
posted on 25/4/03 at 05:19 PM |
What colour's the car?.
You could drill the perspex and use some colour coded tie wraps (big ones) or sikaflex it in place. Don't forget to double the price though or
he'll feel cheated.
yours, Pete.
MK9R
posted on 25/4/03 at 09:45 PM |
How ever its fixed it should slow the car down by a good few mph
I take it he wants it to stop all that naughty wind blowing hos centre parting out of position? Rather than perspex why not use a fine mesh, it will
cut down on wind resistance
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
JohnFol
posted on 1/5/03 at 08:27 PM |
Thanks for all the replies. I have also been looking for someone to etch "Caterham" into the perspex . ..
