Author: Subject: Donkervoort Coupe: hardtop Seven
Mave
posted on 9/3/07 at 07:27 AM Reply With Quote
ch1ef
posted on 9/3/07 at 07:57 AM Reply With Quote
you cant link from piston heads I dont think; look in this news feed for pics Pistonheads link
nib1980
looks like someones copied MNR's front end!
Jonte
posted on 9/3/07 at 08:12 AM Reply With Quote
or the other way around
Click it
CraigJ
posted on 9/3/07 at 08:31 AM Reply With Quote
I like it
designer
posted on 9/3/07 at 08:50 AM Reply With Quote
MNR pinched the design of their front. Very original guys.
Hellfire
posted on 9/3/07 at 09:14 AM Reply With Quote
You don't think Donkey copied MNRs' front really, do you?
nib1980
posted on 9/3/07 at 09:20 AM Reply With Quote
Nope, just the same people having the same idea of style, keeping my head down now, before the law suits come!
David Jenkins
posted on 9/3/07 at 09:21 AM Reply With Quote
Changing the subject (rapidly) from 'who copied who'...
I just don't like the look of hard-top 7's - there are better small hard-tops around that look much nicer. For me, a 7 is basically an open-top car that could, at a push, have a convertible top put on it.
Just my 2p's-worth...
miegru
posted on 9/3/07 at 09:34 AM Reply With Quote
I've always marvelled at Donkervoorts. Technologically they have really pushed the seven concept: windtunnel testing, lots and lots of circuit testing; extensive use of every exotic material they can get their hand on. I think it was also the first seven that was slightly bigger.
Then they stopped selling kits and audi bought them. Now you can buy one for €65.000 in the Netherlands (150bhp). If you really want to treat yourself and include some options and the 275bhp option the pricetag will go over €110.000.
I like sevens but for amounts of €65.000 or higher my wish lists doesn't include one.
Then they make some desisions I really cannot understand:
They had the most beautifull sumpguard I have ever seen: A full undertray made of carbon and kevlar. Nylon 'glide'rails were molded in. It was formed to glide over objects and tested in a windtunnel for added downforce. I have seen the videos of them testing it under a breakyard astra. They hit a metal pole sticking out of the ground (massive round 50mm) at 110km/h. They simply could not break the damn thing. Destroyed 4 cars in the process but the sump held. Marvelous at only 8 kg. You start to believe in the combination of kevlar and carbon looking at that video.
But then they decided it was too expensive (€1500) so they went for another solutions:
They took a 8mm alu plate of 300mmx300mm. Made a bend in it and GLUED it to the sump. The bend is supposed to act to help glide over things. But the only think carrying the impact and load is the sump.
As a techie I get physically upset by these solutions.....
tks
posted on 9/3/07 at 09:38 AM Reply With Quote
muahh
it isn't the same for me.. ..
and i like it when people are creative only my opinion is that the prices are way to high.... for suchs a car, also i don't like this design its way to Futureistic..to early for me... also the space should be very limited inside..atleast the feeling should be there that you are in a cage..
Tks
The above comments are always meant to be from the above persons perspective.
tks
posted on 9/3/07 at 09:48 AM Reply With Quote
i never liked donkervoort and i'm 50% dutch..
the price isn't fair if you ask me, its that simple..
lets face it for 110.000euro i'm sure you can get a very very fast MB
CLK, SLK,S
or maybe even a Ferrari of some kind..
after all i just see them as a more evalueted "us" more dollars...
if we would pick the best 20people of this forum we can build the same stuff they build.
a seven is just to expensive above 45.000euro...
yes i know they need to pay for there NL prod. license, and yes they use brand new audi engines, and yes they chasis is laser cut and hard soldered and yes they won't use donor stuff but 110.000Euro's..
is to much..
Tks
p.d. how hard could it be to strip those dodgy reflectors!!! and put a strip down the rear wing??? its deff no worth 110000euro..
[Edited on 9/3/07 by tks]
3GEComponents
posted on 9/3/07 at 10:34 AM Reply With Quote
Now that would be interesting to see!
Hammerhead
posted on 9/3/07 at 11:57 AM Reply With Quote
it would be interesting.............especially when it came to deciding on bec or cec!!!!!
