Author: Subject: fibreglass filler
andy o
posted on 25/9/07 at 03:30 PM Reply With Quote
fibreglass filler
hi,which is the best bodyfiller to use?any tips on a crack free finish?
thanks andy
nitram38
posted on 25/9/07 at 03:35 PM Reply With Quote
I use easysand. It does what it says on the tin!
SeaBass
posted on 25/9/07 at 04:11 PM Reply With Quote
Depends on what your doing. If your repairing cracks in GRP you'll need to sand back to the mat and lay in a repair then fill.
I was just reading this today for repairing the body on my new project...
Repairing Fibreglass PDF
trextr7monkey
posted on 25/9/07 at 05:08 PM Reply With Quote
We have found these guys
http://www.ecfibreglasssupplies.co.uk/store/
(based in South Shields near Newcastle)
extremely helpful and very locost indeed - they have an e bay shop but it is even better if you collect!
Mike
ps James your old engine now lives in a car in Northern Ireland
[Edited on 25/9/07 by trextr7monkey]
posted on 25/9/07 at 05:16 PM Reply With Quote
For major repairs you'll need to repair underneath with GF matt and then use flowcoat on the top surface (with pigment) to match the external gelcoat. Make sure you match the resin used (likely polyester).
andy o
posted on 25/9/07 at 05:25 PM Reply With Quote
thanks for that so far.i should explain that i'm bonding the doors shut on a fury body,
this further complicated because its being fitted to a striker chassis.i want to fill the shut lines etc and the whole shell will be painted after.
andy o
RazMan
posted on 25/9/07 at 06:14 PM Reply With Quote
Flow coat is usually applied to the inside of panels and is often used to stop light penetration. It has a high wax content so not a good idea to apply it as normal gel coat because it won't polish up nicely and leaves a semi matt finish.
Raz
