Author: Subject: Wide rear wings needed
FlansS14
posted on 22/10/07 at 09:10 AM Reply With Quote
Morning all.
I've fitted 15*8 rims with a Zero offset on the back or my Luego but the std arches do not cover them, I was going to extend the arches by cutting and fibreglassing. but there are two curves and to be honest it would be easy and cheaper to sell the good ones i have and buy some wide ones.
I need some arches 38cm wide. Any ideas.
Flan
Why didn't i just make it simple!
The Great Fandango
posted on 22/10/07 at 09:45 AM Reply With Quote
Found myself in the same boat as you with my Velocity (see thread below)...
Clicky
Still haven't solved the issue and wasn't brave enough to cut my wings for a DIY jobby.
I have just bought a set of cycle wings froma guy on eBay who says he's going to start making rear wings too. You might want to drop him a line?...
eBay seller 'fgm3850'
I'm told that the original caterham wings are a little wider too but I bet they're mega bucks.
Let me know how you get on.
Kyle
He Who Dies With The Most Toys Dies The Happiest
donut
posted on 22/10/07 at 10:03 AM Reply With Quote
Don't DAX do extra wide rear arches?
FlansS14
posted on 22/10/07 at 11:03 AM Reply With Quote
I Looked into getting the Tiger R6 rear archeh but was told i could only get them with the Kit
mookaloid
posted on 22/10/07 at 11:57 AM Reply With Quote
Have a look at the robin hood rear wings . They appear to be just the outer wing bit and the main part some curved ally. should be easy enough to make to fit your application.
Mark
SJC
posted on 24/10/07 at 05:19 PM Reply With Quote
Wide arches
Hi
Might be missing the point but is the wide (280mm) rear arch any good?? Just copied this info off the luego website.
A13 Front Wings (standard 180mm) pair
A14 Rear Wings (standard 215mm) pair
A15 Front Wings (wide 235mm) pair
A16 Rear Wings (wide 280mm) pair
Sorry if this is no help
Stu
FlansS14
posted on 25/10/07 at 08:18 AM Reply With Quote
Thanks for the imput Stu but saidly there not wide enough.
I've decided to make them wider myself after searching with no luck. I've got to Add 9cm extra so i've cut the wing in 2 (about an inch from the inner edge) then carefully wrapped and rivited a piece of ally round the outside.
Now all i have to go is wax up the alloy (to stop the grp bondin) and lay up a few layers off fiberglass on the inside. Ill put some pics up later. hopefully when i remove the alloy its just a case of skimming it with filler,prime and paint.
The total width is 38cm per arch... bit wide
SJC
posted on 25/10/07 at 03:48 PM Reply With Quote
Ok, they are wide.
I was thinking of running 13 x 7 on the rear. I have not done any measurements yet to see if the wide kit will cover the wheels.
Fingers crossed
Good luck with the fibreglassing !!
Stu
bj928
posted on 29/10/07 at 02:59 PM Reply With Quote
been looking around a bit for rear archs but i need insane width rears, i'm running 10J rears with 295/30 18 tyres on, been looking at hot rod and chopper/trike arches, they are about the only arches that come close to mine, or i may make my own from scratch.
front doesn't seem so bad, found some front cycle wings that i think will take the 255 front but i will get the tyres on the rims before i start looking properly.
Volvorsport
posted on 30/10/07 at 11:18 PM Reply With Quote
cheap option is the plastic wings used in tipper cans/lorrys etc .
with a big v10 up front id say you could make your own out of steel and it wouldnt bother it .
www.dbsmotorsport.co.uk
getting dirty under a bus
bj928
posted on 2/11/07 at 01:37 PM Reply With Quote
your right, with v10 weight is not a problem, i've found some mudguards that will fit mine, don't know if they are any good for you, they are the ultra wide on this page :- http://www.crcustoms.co.uk/2.html
FlansS14
posted on 3/11/07 at 08:14 PM Reply With Quote
good find that! mine still needed to be a bit wider though. Ive cut the originals and made them wider. took a bit of filling after to get the shape but they look the part. ill post a pic up tomorrow.
Flan
FlansS14
posted on 7/11/07 at 08:42 AM Reply With Quote
ok all done now.. have a look.
Added 9cm's
http://i13.photobucket.com/albums/a282/FlansS14/05112007253.jpg
and after some filling and primming...
http://i13.photobucket.com/albums/a282/FlansS14/05112007254.jpg
nice and Wide
