Author: Subject: rivet nuts
mkblade
posted on 12/2/08 at 12:08 AM Reply With Quote
rivet nuts
can anyone tell me the correct drill size i need for the following rivet nuts
m8
m6
m5
many thanks simon
flak monkey
posted on 12/2/08 at 07:58 AM Reply With Quote
Depends what rivet nuts you get. They all need different drill sizes unfortunately.
Search for 'insert nut' on http://rswww.com
Sera
http://www.motosera.com
posted on 12/2/08 at 10:20 AM Reply With Quote
6 mm for M4 aluminium rivet nut.
David Jenkins
posted on 12/2/08 at 12:15 PM Reply With Quote
The best solution is to measure the rivnut diameter with a digital vernier (they're cheap enough, if you haven't got one already).
Once measured, go up to the next highest drill size - but no bigger. For example, if the diameter is 6.03mm then go to 6.1mm.
I bought 3 drills with the ideal diameter for the 3 sizes of rivnut I used in my car. These came from Tracy Tools (easily found on Google) and they are kept separate from all my other bits so they're always available (and sharp!).
James
posted on 12/2/08 at 03:30 PM Reply With Quote
As said by others... the hole size depends on the particular riv-nut so measure the ones you have!
I found the thinner walled rivnuts with ridges down the side were much, much easier to set.
James
Macbeast
posted on 12/2/08 at 04:36 PM Reply With Quote
Whatever happened to experimentation ?
My CBS Rivnut tool says :
Steel: M8 - 11mm, M6 - 9mm, M5 - 7mm, M4 - 6mm, M3 - 4.6mm.
Aluminium: M6 - 9mm, M5 - 7 mm, M4 - 6mm, M3 - 5mm.
And adds check if buying from different manufacturer cos size may vary slightly.
Kaspa
posted on 15/2/08 at 07:15 AM Reply With Quote
A word of warning try and avoid alloy rivnuts, if at all posible ; the threads are as weak as chinese tea.
and as someone has already sugested get the surrated edge ones , you will find they grip a lot better into alloy and you dont wind up with a spinning rivnut you cant get the bolt out of.
cheers Kaspa
understeer= when you hit the wall front first
oversteer=when you hit the wall back first
HP= how fast you hit the wall
Torque= how far the wall moves when you hit it
