Scoobythedog
posted on 16/2/09 at 03:02 PM |
SVA Cam Lock
Is anyone aware of a cam lock with edges suitable for SVA ?
Or similar lock,
Scooby
Mr Whippy
posted on 16/2/09 at 03:08 PM |
is this what you mean?
linky
mookaloid
posted on 16/2/09 at 03:18 PM |
Or similar lock,
Scooby
What's it for? bonnet?
Scoobythedog
posted on 16/2/09 at 04:12 PM |
In for an engine cover, (engine in the back) the cover is to be lifted off.
Managed to secure the front, the back of it needs to be secured, liked the idea of the cam lock, just concerned that the edges don't look
profiled.
Scooby
matt_gsxr
posted on 16/2/09 at 04:19 PM |
these,
link
or Aerocatch
Mattlink
twybrow
posted on 16/2/09 at 05:45 PM |
I am in the same boat. Bought a cam lock to secure my bootpanel, problem is, it has a sharp edge that I'm sure would fail. I am looking to see
if I can radius it with either a nut cover, or maybe even some silicone sealant!
Humbug
posted on 16/2/09 at 06:47 PM |
I had the same problem with my boot cover. The solution was to use a wiring grommet of the right diameter for the lock to just fit inside. Best are
the ones where the centre is solid and you cut out the hole yourself, so cut a hole big enough for the lock to go through, slice off the bit of the
gromment that would otherwise go through to the underneath of the panel (so you don't have to make the panel hole oversize) and refit the lock.
The lock should hold the grommet in place, and the grommet willl stop any SVA man's balls from reaching a potentially sharp edge.
This picture shows mine
twybrow
posted on 16/2/09 at 08:42 PM |
Nice solution - thanks for that. I'll look to see what I have grommet wise....
Scoobythedog
posted on 16/2/09 at 10:18 PM |
Humbug, brilliant idea, Will try this, thank you.
