Author: Subject: wiper position
RK
posted on 27/10/09 at 01:17 PM Reply With Quote
wiper position
My boxes are from an MGB, with the triple wiper set up, but I ditched one of them. I mounted the transmission boxes as per Uncle Ron (symmetrically). Now, I get about half the windscreen wiped. It appears the motor doesn't turn that much. Am I completely screwed on this or is there an adjustment I can do?
Wipers are required where I live.
Thanks again people!!
Mr Whippy
posted on 27/10/09 at 01:20 PM Reply With Quote
Have you opened the gearbox? Often you can select a hole further out on the driven wheel that makes the arms then swing further
adithorp
posted on 27/10/09 at 03:21 PM Reply With Quote
As above... but originals had different gear wheels with the peg in different positions. Usually had the angle of sweep stamped on the wheel.
http://jpsc.org.uk/forum/
RK
posted on 27/10/09 at 04:37 PM Reply With Quote
The things you learn, I tell you! I will do surgery tonight and report back.
I am so close to getting this ready, but all these little details are taking so much time. Lights all working again, nosecone needs a couple of coats of paint, bonnet catches need holes drilled, and front wings need gluing (and possibly bolting on). I've decided to proceed with an inspection, even when it starts snowing.
Canada EH!
posted on 27/10/09 at 06:31 PM Reply With Quote
Which will be in a few days.
RK
posted on 28/10/09 at 01:01 AM Reply With Quote
I'd have said that was a cruel comment, except you'll get it before us, and you've probably lived through this all your life. I on the other hand, am a soft West Coast person, who does not adapt.
