paulbeyer
posted on 26/5/04 at 04:44 PM |
Aluminium panels
I'm about to order the aluminium to panel the sides of my car. Do you have to bend the aluminium over the top and bottom chassis rails or can
you panel to the outer edge and fix with Pu adhesive?
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
James
posted on 26/5/04 at 05:08 PM |
AFAIK up to you mate.
Someone (Conrod?) once said the disadvantage of not putting a return on the top of the panel is that the sharp edge digs into your arm- but I'm
not sure how serious that is!
Atb,
James
theconrodkid
posted on 26/5/04 at 05:55 PM |
yo Paul,its hard work bending the sheet,i put mine on straight and put some 1" wide plastic edging i found in a double glazing van
who cares who wins
pass the pork pies
stephen_gusterson
posted on 26/5/04 at 06:15 PM |
put mine flush on bottom edges, folded over on top
atb
steve
posted on 26/5/04 at 06:34 PM |
I did that as well. I got some 1" domed beading in aluminium from B&Q for the cockpit sides. Perfick.
paulbeyer
posted on 26/5/04 at 10:55 PM |
Thanks guys, I guess that's what I'll do as well then - anything for an easy life.
Now then splicing my 4AGE wiring loom into a Premier wiring loom - now that's a differnt story.
stephen_gusterson
posted on 27/5/04 at 10:02 AM |
bear in mind if you use the soap and blowtorch annealing method, the top will be a lot easier to fold over......
atb
steve
