franky
posted on 14/9/10 at 08:37 AM |
Decent finish with u-pol cans?
How good a finish could I expect by using U-pol etch primer/high build primer then gloss white on my ally panels using U-pol rattle cans? Has anyone
done similar?
thunderace
posted on 14/9/10 at 08:49 AM |
i put all my cans in a jug of very hot water to heat the paint up it helps you get a better finish .
MakeEverything
posted on 14/9/10 at 08:51 AM |
It says to use that can at room temperature anyway. Helps the paint flow through the nozzle and gives you a better spray pattern - yes, even out of a
can.
Kindest Regards,
Richard.
franky
posted on 14/9/10 at 09:50 AM |
With properly prepared panels and by taking your time would you say its possible to get a nice finish?
RK
posted on 14/9/10 at 11:30 AM |
My experience with my interior side panels, and rear glass fibre wings is that yes, it can look very good. Polish after sanding through the grades
(you know the drill: 250, wet 400, wet 600, wet 1000) and it will be a nice shiny finish. You will need several coats and perhaps a couple of dozen
cans to get a really durable finish though. My wings alone took about 10.
For your side panels, sign vinyl looks good and isn't very expensive on fleabay. This is what I did. I would start on smaller pieces if you go
the spray can route. It can be a bit frustrating at times!
40inches
posted on 14/9/10 at 11:51 AM |
Very good products and finish. They do a universal plastic primer that will prime PP, 600ml for around a fiver.
loggyboy
posted on 14/9/10 at 12:53 PM |
At £6 a can plus primer, prep materials and time, wouldnt it be easier to take them to a bodyshop?
big_wasa
posted on 14/9/10 at 03:32 PM |
Its taken two tins just to get my new spoiler primered to a good standard.
I would also take it to a body shop.
franky
posted on 14/9/10 at 05:11 PM |
I've got a compressor and a small gun, I guess its worth just having a go with that to see what it looks like......... then in 24months time
when I've got some cash take it to a body shop!
RK
posted on 14/9/10 at 09:04 PM |
Many body shops in my neck of the woods won't do individual pieces and the ones that do are very expensive. cheaper to use cans and sand
down/polish yourself. Plus, if you wreck it you can always touch it up yourself.
beaver34
posted on 14/9/10 at 09:53 PM |
got my alloy panels powdercoated, prepped myself cost about £80 for all interior items and full side panes doing, loads better than painting
