Author: Subject: Wurth Adhesive
Donners90
posted on 21/10/04 at 02:09 PM Reply With Quote
Wurth Adhesive
I am looking to fix the front mudguards and I have heard that Dax use a setting adhesive made by Wurth. Has anyone here used it? Is it recommended - advantages / disadvantages? And where can I get it? Maybe there are other products to do the same job??
According to a colleague he hasn't had any problems with it and he's been driving around all summer in his Dax and they haven't come off yet!!!.
Just seeing if there is a way (your opinions welcomed) to mount the mudguards without having to drill them!!
James
[Edited on 21-10-2004 by Donners90]
locoboy
posted on 21/10/04 at 03:12 PM Reply With Quote
Sikaflex - does the job as far as i know MK swear by the stuff
Locoboy
Markp
posted on 21/10/04 at 06:29 PM Reply With Quote
I've used Wurth and it is almost exactly the same as Sikaflex (just a different name) Not bad stuff, should be ok for what you need it for
Mark
Hugh Paterson
posted on 21/10/04 at 08:44 PM Reply With Quote
Or you could encapsulate big heads into the wings as u laminate em and just use a good old washer & nut like I do
Shug.
Spyderman
posted on 22/10/04 at 03:28 PM Reply With Quote
If you are going to laminate anything into the wing it may as well be the bracket!
That way it will be slimmer.
Terry
Spyderman
Ian Pearson
posted on 22/10/04 at 07:25 PM Reply With Quote
I used Sikaflex & then fibreglassed over the bracket.
r3nuf
posted on 27/10/04 at 01:17 PM Reply With Quote
P U Sealant
You can get Wurth's PU Sealant from this guy who can sell it direct.
It is the equivalent of Sikaflex, but generally a fair bit cheaper. Available in various colours.
Ring this gentleman...Andy Cocker 07789 745532. He should be able to help you.
Gary
Drive Fast....Brake Late....Take Chances
givemethebighammer
posted on 27/10/04 at 09:29 PM Reply With Quote
is U-Pol "tiger sealant" (black PU adhesive stuff). The same as the above products ?
Browser
posted on 28/10/04 at 10:02 AM Reply With Quote
What it so wrong with bolting them on? That way if they get dinged, which I am sure they are vulnerable to, they are not going to be a total arse to get off?
ASH3
posted on 29/10/04 at 08:20 PM Reply With Quote
DONT STICK EM!!!
You will always be watchin them
and when they let go ITS TO LATE
Been there done it ,they dont half
fly at 80+.
