Jasper
posted on 31/1/03 at 10:11 AM |
Ali panels under engine bay
Doing the ali panels at the moment. With the bike engine install there is LOTS of free space in the engine bay. I would like to ali panel it all over
except where the bike engine is, to keep at the cr*p out. Are there any reason - aerodynamic/cooling that I shouldn't do this???
GO
posted on 31/1/03 at 11:17 AM |
From an aerodynamic point of view its an excellent idea. Smoothing airflow is always good for reduced drag, and doing this underneath will help reduce
the air pressure under the car and thereby increasing downforce (more like decreasing lift really, but you get the point).
Not sure about the cooling issues, but I'm sure you'd have to be careful from that aspect.
When I get there, I intend to make the underside as flat as possible.
Jim
posted on 31/1/03 at 02:01 PM |
MAC 1 have a metal sheet desigend to go under a blade car. i'd imagine they would be able to make one with al the correct bends etc for your engine.
When i asked about them they did point out about the cooling being a potential probelm. give them a ring
Jim
Jasper
posted on 31/1/03 at 04:10 PM |
Thanks Jim, I do speak to Mark at Mach 1 regularly when I get stuck anyway!
It would be very easy just to cut flat pieces to fit, it's the cooling that worries me a bit - but I think the rad should take care of that - it's
bigger than the bike rad, with a much more powerful fan.
Spyderman
posted on 31/1/03 at 04:26 PM |
Have you allowed for an exit for the rad cooling air?
If not you could get overheating problems as well as poor engine running due to hot air being drawn into engine.
Terry
Spyderman
Jasper
posted on 31/1/03 at 05:43 PM |
Good point, I was gonna leave an area in front of engine open, but maybe this isn't much a good idea....
Liam
posted on 31/1/03 at 07:28 PM |
I also plan to panel as much of the bottom of my car as possible. My rad air is gonna be ducted out the bonnet just behind the nosecone (I think
I've seen some w***fields like this). I'll also duct some air in from somewhere to run past the engine/exhausts (I was thinking maybe naca ducts
but people'll think I'm a posey ponce). This'll exit with cool looking dax-style vents at the back sides of teh engine bay - like this...
liam
stephen_gusterson
posted on 31/1/03 at 08:54 PM |
i would have thought you needed an open area at the rear bottom of the engine compartment open at least, or there will be a heat pocket.
atb
steve
Jasper
posted on 31/1/03 at 09:20 PM |
There will be one their anyway as that's where the engine sits just below the bottom chassis rail.
As for other ducts it's a nice idea but my ali panelling is at a pretty basis stage and I want the car finished b4 Le Mans!
stephen_gusterson
posted on 31/1/03 at 11:10 PM |
on the xj-s (i used to have one, thats why I quote it a lot!) there was a heat problem undr the bonnet.......
the front 'splitter' under the front valance is apparently vital to cooling. It creates a vacuum under the car to help the air flow from the rad,
past the engine, and out.
as far as pannelling around the engine is concerned - a lot of new cars seem to like putting plenty of plastic crap over the engine and surrounding
area to look good - or cut the noise down?
atb
steve
Jasper
posted on 1/2/03 at 10:34 AM |
After thinking about the Dax's side vents they would be pretty easy to make, maybe that's the way to go.......
posted on 4/2/03 at 06:15 PM |
vent position
I read somewhere that the louvre vents on top of a bonnet are purely decorative as they are in an area of low pressure and vents placed at the side
are much more effective at removing hot air. I found that before I boxed in my pedals the hot air usually found its way into the cockpit and made my
feet sweat.
yours, Pete.
Jasper
posted on 4/2/03 at 07:34 PM |
After spending most of the day cutting all the holes for the suspension in the ali side panels and making it all fit I can't be assed to do any
vents! Just not gonna bother panelling the bottom.....hopefully by keeping things simple I'll have it on the road this summer!
carnut
posted on 24/2/03 at 10:27 AM |
As to the bonnet loovres being in an area of low pressure. This is true but aids cooling because they are in an area of low pressure on the outside
therefore will suck out air from the high pressure in the engine bay caused by the ram air effect of the open nosecone.
procomp
posted on 2/3/03 at 11:17 PM |
panneling
The side exit duct's as shown on the dax will work fine for cooling with fully enclosed engine bay as we at procomp have been doing it that way on
westfield' for 16 years.
