Bigheppy
posted on 12/9/10 at 12:43 PM |
quote: Originally posted by Bigheppy
Curtain wire can be used as a liner the plastic coating had to be removed to fit into the torch on my cebora 130. And its cheap.
errrmmmmmm, without looking, I bet that is larger diameter so it may be more difficult to push trhough the hose.
Threaded through the hose with no problems, the diameter is the same as the plastic liner it replaced.
v8kid
posted on 12/9/10 at 01:34 PM |
How do you get the curtain wire to terminate in the gun?
The original appears to be stuck in. Ant pics?
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
martyn_16v
posted on 14/9/10 at 06:39 PM |
quote: Originally posted by v8kid
I hooked up a laptop power supply to the drive motor electrics 6 months ago in addition to the brace.
Details on various welding sites.
Works well and is cheap
Same here, although i'd leave this mod until last. Changing the liner to a good quality steel one, and bracing the feed rollers made far more of
a difference, you may find you're happy with it with just those two changes.
I only changed the motor power supply because I happened to have the bits kicking about, and because I can't leave well alone. It does change
the 'feel' of the welder, it doesn't labour for a second as you strike up, and the wire feed stops much faster when you let go of
the trigger. It's also more consistent, I used to be able to hear the wire feed speed up and slow down before. All in, I now get better looking
welds from it.
The Black Flash
posted on 16/9/10 at 11:10 AM |
quote: Originally posted by MakeEverything
aaaah, this is a good idea.
Might try this with mine.
Yup, I made one of these for mine and can confirm that it helps a great deal. The plastic supports for the rollers are just too bendy, this brace
holds them steady.
DIY Si
posted on 18/9/10 at 12:10 PM |
I've now fitted my new steel liner and made up a bracket to hold the drive wheels in place, and it has made the world of difference to the
welder! It now works much more smoothly and I can get into tighter spaces without worrying about things too much. Well worth the £17.
Sun Tzu, The Art of War
