Triton
posted on 14/1/06 at 11:25 PM |
Moulds are best left for weeks rather than days before cracking them...gel can take a day or just a few hours to go off before you can start with the
matt....depends on the squirt added.
www.tritonraceseats.com
www.hairyhedgehog.com
Triton
posted on 14/1/06 at 11:26 PM |
Buy the buckets from cfs they are as cheap as chips and last ages if you crack the old stuff out....same goes for brushes if you look after them.
Avoneer
posted on 14/1/06 at 11:45 PM |
Apart from that - how did I do???
Pat...
Triton
posted on 14/1/06 at 11:52 PM |
Ok matey....suggest you get one of those vapour masks from CFS..(£12+vat).awesome as you can't smell the resin etc which after 8+hrs can give
you a really mad headache....
Avoneer
posted on 15/1/06 at 12:09 AM |
And wee off the wife if you're garage is under your house and the smell drifts through the house for a couple of days!
Pat...
Triton
posted on 15/1/06 at 11:26 AM |
Be carefull with the catalyst as well as it has been known for it to go up in flames all on it's own....if you spill it make sure you mop it up
with wet rag and throw the rag in a bucket of water.
I bet your wife loves you then Pat, glassing under the house....
stevebubs
posted on 15/1/06 at 02:14 PM |
OK...So my method ss spot on with the vital exception of rolling out the gelcoat...
Got to order some more on Monday to finish the job now.....
stevebubs
posted on 17/1/06 at 06:47 PM |
3 Layers of matting now applied (1 x 300gsm, 2 x 600gsm). Here it is after the 2nd layer...
2nd Layer of Matting
And a close-up...
Close-up of 2nd layer
I'm hoping this is probably enough glassing? By my logic, the 3 layers I've applied are the equivalent of 5 x 300gsm layers....
[Edited on 17/1/06 by stevebubs]
Hugh Paterson
posted on 19/1/06 at 12:03 AM |
We wait with baited breath
Shug.
