<<  1    2  >>
Author: Subject: Bonnet Catches
RazMan
posted on 27/2/07 at 11:39 PM Reply With Quote
Yep, that's why Dhuz fasteners were invented
Raz
posted on 28/2/07 at 12:15 AM Reply With Quote
The screws can be done up with a 10p piece once the c/s is formed.
Would a 2p piece do it, we don't want to go too mad do we ?
907
posted on 28/2/07 at 12:30 AM Reply With Quote
Tut tut. Don't you know anything Pete?
By using a 10p with it's aluminium/nickel content I will lower the electrolytic corrosion factor.
Just imagine the problems I'd have with copper on ally. I would age harden before reaching my prime.
Paul G
Gaz 1977
posted on 28/2/07 at 09:02 AM Reply With Quote
they look good, I cant see any problems with the addition of some PTFE tape
You do remember your engine is a LOTUS, getting to the engine quickly and often will be essential.
Is the ten pence to call the RAC.
posted on 28/2/07 at 09:19 AM Reply With Quote
You'll be OK with a 2p coin - most of them are made of steel these days, with a thin copper covering!
Fred W B
posted on 28/2/07 at 11:19 AM Reply With Quote
I like, except for the potential for losing the screws if you take them out at a filling station or whatever. Suppose you could keep some spares in the car though.
cheers
Fred W B
posted on 28/2/07 at 05:52 PM Reply With Quote
Would the screws have a big enough surface area to spread the load without pulling through the ally? Perhaps some button headed stainless screws might be better and still be SVA friendly?
posted on 28/2/07 at 05:58 PM Reply With Quote
This is an idea I had a while back for a "hidden" fixing (sorry for abusing your Paint creation!).
Essentialy you mount a couple of pins into the chassis rail, and a strip with keyhole cutouts is used to lock into a recess machined into the pins. This can be moved by a lock mechanism from the outside. There are a some issues to solve, how do you retain the strip in place for starters (a couple of slots cut in it and an a screw, washers and spring and nut to keep it under tension maybe).
By suitably forming the strip around the keyhole it could be made to pull the bonnet down as it engages with the pin.
907
posted on 28/2/07 at 09:42 PM Reply With Quote
Hi Rusty
The idea behind using counter sunk screws is that the c/s would be a positive location into the c/s of the lug.
On first assembly the bonnet would be clamped in position and the screws inserted and the ally c/s formed
when tightening the screws for the first time.
On refitting it must go back in the same place.
As for pulling through, when I did the test one it took a spanner on the hex shaft of the screwdriver to c/s the ally sheet.
The trouble with dome or pan heads (and Dzus) is you would need a clearance hole that would allow the bonnet to move
if the screws were not really tight.
I'm going to dismiss the vibrating loose issue.
Vibration???? From a Lotus engine/????
I like your idea Mike. Going to think about that one.
Atb
Paul G
caber
posted on 28/2/07 at 11:15 PM Reply With Quote
Great British sports Cars have SVA rubber pull down catches on Ebay at £10 a pair ATM, I went for this.
I do like the screw in solution, a bit of old inner tube rubber on the receiver surface may be enough to prevent them rattling loose.
You may be able to get an M5 star washer to go up the thread of the screw to save it falling out of the panel when you unscrew it, if not try some UNF star washers about the same size.
I wish I had seen this or thought of the pull in countersink for my dashboard before I fitted it with cups!
well done!
Caber
<<  1    2  >>
