StevenB
| posted on 13/11/08 at 10:54 PM |
Bodywork fitting query
Before I start to hack away at this can anyone advise as to the best way to cut back and fit the bulkhead tray and scuttle?
I would rather take as little as possible out
of the scuttle.
S
StevenB
| posted on 13/11/08 at 11:25 PM |
Ah! I thought the scuttle went over the top
of the tray and at the same time hiding the top
cut edge of the tray.
Thank God for that. Talk about "if in doubt - ask"
RK
| posted on 14/11/08 at 03:28 AM |
That sure looks nice. Why does everyone else's seem to look so good while mine looks like shit?
alistairolsen
| posted on 16/11/08 at 02:22 PM |
Where are those panels from and will they fit a homebuild book locost?
RK
| posted on 16/11/08 at 04:55 PM |
The Haynes Roadster book tells you how to make them. Those in white just have an extra lip on it on the front, which helps with the look, and I guess
drainage. I've run out of ally, so I can't do that.
The Gibbs breaks it down into two halves, which is easier to bend.
| posted on 16/11/08 at 07:00 PM |
All the panels in the pictures (apart from the carbon fibre aeroscreen on the white car) are from MK. I'm not sure which, if any, would fit a
home built book locost though. (Other than front and rear wings)
Phil
