Author: Subject: radiator
dunk3
posted on 1/12/08 at 10:00 AM Reply With Quote
radiator
hi all I am looking to buy my radiator and fan but i am unsure which one i need .I will be fitting it to my mk indy with a zetec. I have been told to use vw polo or escort but when i phoned to order one they asked which one, what size, what year. Can anyone tell me which one they have used and where you got it from. cheers
jabbahutt
posted on 1/12/08 at 10:08 AM Reply With Quote
a VW302 which I believe is from a 1.0 Polo. www.radiatorsonline.co.uk has diagrams so you can double check connection points etc as i didn't use a zetec engine.
As for the fan I bought one from CBS. I just told them the available core height and they sent me a fan which was a perfect fit.
Hope that helps
Nigel
[Edited on 1/12/08 by jabbahutt]
Mr Whippy
posted on 1/12/08 at 10:14 AM Reply With Quote
note though that not all polo rads will fit in an MK nose cone, especially the type with the filler cap on the side
jabbahutt
posted on 1/12/08 at 10:24 AM Reply With Quote
VW302 doesn't have a filler cap which is why I used it. i believe the original set up used an expansion tank which is what I've done.
It needs to be fitted at a sloping angle of about 10 degrees to allow hoses to bend around chassis rails but is a decent fit and fills the aperture in the nose cone.
No problems with keeping a 2.0 pinto cool.
Nigel
Mr Whippy
posted on 1/12/08 at 10:29 AM Reply With Quote
this polo Mk2 81-83 1.3 ( 2VW108 ) rad will not fit in the MK as its too wide, pity as the filler would be handy, use the one jabbahutt recommends
sickbag
posted on 1/12/08 at 10:37 AM Reply With Quote
These guys are doing the VW302 for £38 delivered.
http://www.adrad.co.uk/icegroup/adrad/new/prices.php?id=VW302&model=POLO&make=VOLKSWAGEN
Finally back on the job!
posted on 1/12/08 at 11:03 AM Reply With Quote
Give MNR a ring, they'll sell you the correct one.
cjtheman
posted on 4/12/08 at 08:22 PM Reply With Quote
hi
big thumbs up for advanced radiators
ordered mine on line 5pm thursday
was delivered by 3pm next day well packed and perfect condition
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
