r1_pete
posted on 7/12/08 at 03:10 PM |
WTD, 48mm OD 3mm wall mild steel tube
I need about 500mm of 48mm Outside diameter, 3mm wall mild steel tube, anyone know if this is a standard size? know of a supplier, or have a bit
kicking around, 4 x 150mm offcuts would do....
Cheers.
Pete.
Miks15
posted on 7/12/08 at 03:36 PM |
Sorry cant help you out with the tube but i can say it is a standard size
907
posted on 7/12/08 at 03:45 PM |
That would be 1 1/2" nominal bore if that's any help.
Paul G
MkII
posted on 7/12/08 at 04:55 PM |
very common size any steel stockholder or most fabrication shops would have some only about 50p ft new .m.
Trems
posted on 7/12/08 at 05:04 PM |
there is some stainless on the bay?
http://cgi.ebay.co.uk/Stainless-steel-tube-48mm-OD-3mm-wall-1970mm-long_W0QQitemZ260252156198QQcmdZViewItemQQptZUK_BOI_Metalworking_Milling_Welding_Me
talworking_Supplies_ET?hash=item260252156198&_trksid=p3286.c0.m14&_trkparms=72%3A1301%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
www.tR3M5.com
r1_pete
posted on 7/12/08 at 05:18 PM |
Thanks for the replies chaps, there's a stockholder not far from me I'll give them a try....
Rather not use stainless, I need to weld it to mild steel flange, and do a bit of machining on the ends for the throttle body connections.
Cheers.
Pete.
welderman
posted on 7/12/08 at 06:59 PM |
think ive got some, will look tomorrow
Thank's, Joe
I don't stalk people
