Danozeman
posted on 14/12/08 at 01:06 PM |
seat belt mount threaded bar/tube.
Wheres the best place to get thread bar from for seat belt mountings to weld into a roll bar?
[Edited on 14/12/08 by Danozeman]
Dan
omega 24 v6
posted on 14/12/08 at 01:29 PM |
You'll need to be able to prove it's high tensile to 8.8 grade for SVA.
Any bolt/fastener supplier will have it (and a spec sheet)
Band Q do it (but no spec Sheet I doubt)
Danozeman
posted on 14/12/08 at 01:33 PM |
I meant Internal threaded bar. probably should have said tube.
My bad.
Dan
blue2cv
posted on 14/12/08 at 01:39 PM |
Std thread is 7/16" UNF, may help with your search
maartenromijn
posted on 14/12/08 at 01:43 PM |
I have been searching as well. I ended my search at McGill on Ebay. They only have threaded bushes, which are too short.
I think a friend with a lathe might come in handy...
BLOG: http://thunderroad-super7.blogspot.com/
JC
posted on 14/12/08 at 04:40 PM |
try short track 123 (Jason) on here, he did some for me
Trems
posted on 15/12/08 at 10:11 AM |
Do it yourself mate, the drill size for a 7/16 UNF thread is 9.9mm. So buy some tube 15mm OD with a 3mm wall thickness, then drill it to 10mm ID and
tap the thread...job done
www.tR3M5.com
